Axle check straps
I am thinking of fitting some axle check straps to my 90.
I recently fitted X-arms and springs, with 11" shocks. It rolls a bit more on corners than before and I can feel the spring lifting off it mounts :o
I think check straps might be a good idea when using the vehicle on the road :lol:
Anyone know of a decent supplier?
Cheers
What shocks have you got?
I would think that if you had the same spring and damper ratings as before the roll shouldn't have increased, maybe the shock you have fitted have much softer damping...
I know that of the ones Gwyn sells the Old man EMU and the Terrafirma have quite firm damping - the others are much softer.
