wib Posted April 14, 2009 Share Posted April 14, 2009 i bought a milmarker winch off ebay just need some information so i can fit the winch can the winch go eney way ie pump left or right thanks ian Quote Link to comment Share on other sites More sharing options...
gazzer Posted April 14, 2009 Share Posted April 14, 2009 i bought a milmarker winch off ebay just need some information so i can fit the winch can the winch go eney way ie pump left or right thanks ian PM Rangeyrover he has got one fitted to his RRC. Quote Link to comment Share on other sites More sharing options...
RangeyRover Posted April 14, 2009 Share Posted April 14, 2009 i bought a milmarker winch off ebay just need some information so i can fit the winch can the winch go eney way ie pump left or right thanks ian Do you mean the winch motor? Mine is on the drivers side. I used a disco winch bumper which suited it. Dog sloooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooow on the RR PS pump tho. Quote Link to comment Share on other sites More sharing options...
wib Posted April 14, 2009 Author Share Posted April 14, 2009 Do you mean the winch motor?Mine is on the drivers side. I used a disco winch bumper which suited it. Dog sloooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooow on the RR PS pump tho. i got a zf 74 pump so shouldnt be sloooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo ooooooooow thanks for your help Quote Link to comment Share on other sites More sharing options...
RangeyRover Posted April 14, 2009 Share Posted April 14, 2009 i got a zf 74 pump so shouldnt be slooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooow thanks for your help Good, That should be an improvement. Please post pics of setup when complete. The thing with hydraulic is it wont "race" when under no load like electric winches. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted April 14, 2009 Share Posted April 14, 2009 If I understand what you are asking...................... Look at the motor mounted to the drum, it uses 2 bolts, there are 2 bolts not used, you can undo and rotate motor to a different position to suit Nige Quote Link to comment Share on other sites More sharing options...
m&mv80 Posted April 15, 2009 Share Posted April 15, 2009 i think you mean what way around to fit the winch?? i fitted mine with the gearbox on the drivers side, cant remember why though, not sure if it matters to be honest but prob best to find out for sure, try 4x4winches.com oh and i upgraded from a zf74 because it was still sooooooooo slow hth martin Quote Link to comment Share on other sites More sharing options...
Anderzander Posted April 15, 2009 Share Posted April 15, 2009 What did you upgrade to Martin? Stephen Quote Link to comment Share on other sites More sharing options...
wib Posted April 16, 2009 Author Share Posted April 16, 2009 i think you mean what way around to fit the winch??i fitted mine with the gearbox on the drivers side, cant remember why though, not sure if it matters to be honest but prob best to find out for sure, try 4x4winches.com oh and i upgraded from a zf74 because it was still sooooooooo slow hth martin what pump did u upgrade to martin thanks Quote Link to comment Share on other sites More sharing options...
m&mv80 Posted April 16, 2009 Share Posted April 16, 2009 hi, i cant remember the exact spec of the pump but i think it is about 35cc and is run off the pto on the transfer box, im led to believe it is a superwinch item and was origionally fitted to a landrover cherrypicker, all piped in 1/2 inch hose and a manual spool valve it was the best mod i ever done as it totally transforms the winch martin Quote Link to comment Share on other sites More sharing options...
wib Posted April 19, 2009 Author Share Posted April 19, 2009 hi, i cant remember the exact spec of the pump but i think it is about 35cc and is run off the pto on the transfer box, im led to believe it is a superwinch item and was origionally fitted to a landrover cherrypicker, all piped in 1/2 inch hose and a manual spool valve it was the best mod i ever done as it totally transforms the winch martin used the winch today very strong just abit slow? Quote Link to comment Share on other sites More sharing options...
RangeyRover Posted April 19, 2009 Share Posted April 19, 2009 this pump is worth a think for your application it will make it fly. Are you still using the solenoid control valves that came with the MM? They will limit flow to 13 l min even if the pump can do more, so they need to be replaced too I'm delighted with my winch but not with the pump so I'm working on a similar solution, but if I had seen that pump and clutch last year I would have bought it no question. RR Quote Link to comment Share on other sites More sharing options...
wib Posted April 20, 2009 Author Share Posted April 20, 2009 this pump is worth a think for your application it will make it fly.Are you still using the solenoid control valves that came with the MM? They will limit flow to 13 l min even if the pump can do more, so they need to be replaced too I'm delighted with my winch but not with the pump so I'm working on a similar solution, but if I had seen that pump and clutch last year I would have bought it no question. RR ye still usein the mm solenoid control valves. that pump is the bees .i need a new solution to let me know how u get on . were do u think i would get the solenoid control valves changed? thanks RR Quote Link to comment Share on other sites More sharing options...
RangeyRover Posted April 20, 2009 Share Posted April 20, 2009 Hi m8, I'm not sure how easy it is to interface to the motor when it was bought with the MM solenoid configuration. I bought mine like that and may yet regret it. In all honesty I haven't got as far as you, you do at least have a configuration that runs the winch at proper speed. If you can solve the connection and pump problem, then there are 2 options. A replacement solenoid that can flow a decent rate, maybe a 12v version of this this would mean the winch would be a switch, ie on full speed or off. a lever valve that would control flow and therefore the rate of the motor. Something like this But is a PITA to mount in the cab and route the lines and what if you want more than operating point? So I guess that I am leaning toward the solenoids for me Quote Link to comment Share on other sites More sharing options...
wib Posted April 20, 2009 Author Share Posted April 20, 2009 Hi m8,I'm not sure how easy it is to interface to the motor when it was bought with the MM solenoid configuration. I bought mine like that and may yet regret it. In all honesty I haven't got as far as you, you do at least have a configuration that runs the winch at proper speed. If you can solve the connection and pump problem, then there are 2 options. A replacement solenoid that can flow a decent rate, maybe a 12v version of this this would mean the winch would be a switch, ie on full speed or off. a lever valve that would control flow and therefore the rate of the motor. Something like this But is a PITA to mount in the cab and route the lines and what if you want more than operating point? So I guess that I am leaning toward the solenoids for me a new solenoids pack sounds about right with a decent flow rate and upgrade the pump to a good flow rate ? Quote Link to comment Share on other sites More sharing options...
wib Posted April 23, 2009 Author Share Posted April 23, 2009 spoke to alan from alfred winch today he told me to go down the route of 2 zf 74 pumps running together ? Quote Link to comment Share on other sites More sharing options...
RangeyRover Posted April 23, 2009 Share Posted April 23, 2009 spoke to alan from alfred winch today he told me to go down the route of 2 zf 74 pumps running together ? He's right, in as much as it will give you more flow. That would be then an investment of £400 in pumps dangerously close to the price of the imported pump I listed at the top, and still doesnt get rid of the obstruction of the standard solenoid pack. I would personally change those first. As Im cheap, I would run 2 omega pumps in parallel, if I was going to use power steering pumps. I still think that one of the monsters from muncie KILLS the pump problem dead, but seriously the standard solenoid is your limiter at the moment. Have a look here, as It has been discussed before In fact, it is stated in that thread that the standard Valve can do 26 L/min, SO I dunno.... Quote Link to comment Share on other sites More sharing options...
