Jamest535 Posted March 3, 2006 Share Posted March 3, 2006 I have got a few extra things on my disco, and when everything is on, i need the throttle to increase abit, so how do you and has anyone put a little thottle stick or something on there disco to increse the REVS. Cheers Saferi 1998 TDi Auto Quote Link to comment Share on other sites More sharing options...
Matt Neale Posted March 3, 2006 Share Posted March 3, 2006 I have got a few extra things on my disco, and when everything is on, i need the throttle to increase abit, so how do you and has anyone put a little thottle stick or something on there disco to increse the REVS. CheersSaferi 1998 TDi Auto If I've read your post right, you've got a late Tdi Disco, you've added some extra electrical kit (lights / winch etc I assume) and you want to know if anyone has fitted a hand throttle? Easiest (and cheapest) way is to use a universal choke cable. That's the way I went with my Tdi 110 - You should be able to find a space either on the column shroud or dash to mount one neatly. You'll need to drill the throttle arm on the injector pump and fit a suitable connector (eg a bicycle brake caliper bolt) to connect the cable inner. When I get the chance I'll take some pics of my setup so you can see what I mean. Cheers, Matt Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 4, 2006 Share Posted March 4, 2006 If you wanted to be a bit sexercisey and modern about it, you could find an idle air valve from a scrap car (most EFI cars have one somewhere) and connect it to a dashboard switch. If you put a restriction in line with it you could fine-tune it to give the desired RPM lift. I think some Range Rovers have such a valve, actuated when the air-con kicks in. Quote Link to comment Share on other sites More sharing options...
