Defender Td5 Fuel Pump
What sort of Defender? WFX000260 fits a 110 and I think a 130, but I think the pump in a 90 is different due to the different tank. It certainly is in a Discovery, you can fit the 260 pump because it is the same pump but the fuel gauge part is different and reads wrong.
Sorry 110 Hi-cap.
You could do better than replace the whole assembly (pump + float arm and fuel sender + big plastic box): you could open the plastic box and replace only the pump unit, which has a VDO-Siemens code as follows: A2C59511614, and is the same irrespective whether it is for a 90, a 110 or a disco II.
This allows to save a good amount of money: the pump unit price is here in Italy 160 euros, while the price of the complete assembly ranges from 350 to 400 and more (it depends on the place you buy it, whether from a dealer or from other sources).
