simonr Posted March 4, 2006 Share Posted March 4, 2006 Do you know what the thread sizes of the different bolts used to hold, principally 90 rear and 110 front calipers on to the axle are? I'm making fiddle brakes at the moment and I need to tap the bracket which bolts on to the axle with an appropriate thread. The brackets will take RR Rear or 110 front calipers and although I have both calipers,I dont have any of the bolts to guess the thread from. Any ideas would be appreciated. Si Quote Link to comment Share on other sites More sharing options...
western Posted March 4, 2006 Share Posted March 4, 2006 (edited) From EPC Defender front & rear from VIN LA930456 M12 X 35mm RR Classic Front & rear UNF 7/16" or M12 x 35mm doesn't tell me thread pitch, I assume standard 1.5mm pitch on the M12 bolts hope that helps Edited March 4, 2006 by western Quote Link to comment Share on other sites More sharing options...
minivin Posted March 4, 2006 Share Posted March 4, 2006 From EPC Defender front & rear from VIN LA930456 M12 X 35mm RR Classic Front & rear UNF 7/16" or M12 x 35mm doesn't tell me thread pitch, I assume standard 1.5mm pitch. hope that helps 7/16" UNF is 20TPI if that helps Quote Link to comment Share on other sites More sharing options...
simonr Posted March 4, 2006 Author Share Posted March 4, 2006 7/16" UNF is 20TPI if that helps Fantastic - Thank very much! Si Quote Link to comment Share on other sites More sharing options...
minivin Posted March 4, 2006 Share Posted March 4, 2006 Fantastic - Thank very much!Si no probs Quote Link to comment Share on other sites More sharing options...
