Ivan Posted April 17, 2009 Share Posted April 17, 2009 My wifes defender keeps getting a strange vibration. It occurs at about 45mph and feels like you are driving over corrugations. The whole vehicle vibrates but you can't feel it through the steering wheel (IYSWIM). What I have done so far is :- Removed front prop and test drive - No difference but the vibration does seem a little less. Removed rear prop and test drive - Same results as above Removed rear half shafts and test drive - Same as above Had all the wheels balanced - No difference. Checked all wheel bearings - No discernable play in them. BTW I also checked all the UJ's in the props, no play and all well greased. Anything else I should check ? TIA Ivan Quote Link to comment Share on other sites More sharing options...
western Posted April 17, 2009 Share Posted April 17, 2009 Swivels on front axle, may need reshimming to book spec to clear it. Quote Link to comment Share on other sites More sharing options...
Aragorn Posted April 17, 2009 Share Posted April 17, 2009 Wouldnt you expect swivel play to be felt thru the steering? Vibrations that are felt thru the vehicle but not the wheel are generally from the rear end. I'd be checking the bushes and A-Frame balljoints. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted April 17, 2009 Share Posted April 17, 2009 Check the bushes etc. Quote Link to comment Share on other sites More sharing options...
Ivan Posted April 17, 2009 Author Share Posted April 17, 2009 OK thanks for the pointers. I will try and change all the bushes on the rear end this weekend and see if it makes any difference. Rgds Ivan Quote Link to comment Share on other sites More sharing options...
