Froggie Posted April 18, 2009 Share Posted April 18, 2009 I have a 51 plate Discovery TD5 which is making a whistling & wining sound. When I accelerate (even just touching the accelerator) there is a whistling sound coming from engine it also appears to be more noticable from inside the truck rather than outside. Along with the whistling there is a sound that i can best describe as an off road motorcylce running on 1 cylinder (if they have more than one). as the truck goes faster the noises are gradually drowned out by the "normal" sound of the engine, if I remember correctly the noises have gone by about 2500-3000 RPM. Any ideas? Thanks Steve Quote Link to comment Share on other sites More sharing options...
oggie27_3 Posted April 19, 2009 Share Posted April 19, 2009 sounds to me like the exhaust manifold is warped, and possilbly a sheared manifold bolt or 2. had same problem on mine. hth. jon Quote Link to comment Share on other sites More sharing options...
Froggie Posted April 20, 2009 Author Share Posted April 20, 2009 sounds to me like the exhaust manifold is warped, and possilbly a sheared manifold bolt or 2. had same problem on mine. hth.jon I will check that, possibly done some damage while I have been off road, are manifolds expensive? Steve Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 20, 2009 Share Posted April 20, 2009 I would check the turbo pipework - especially after the turbo - where the intake air is under pressure. With the engine running, run your hand around the pipe to feel for air pressure leaks. You may also notice a drop in performance if the leak is significant. Inlet manifold leak will usually be noticeable by a drop in performance, higher fuel consuption, rough idling, excessive turbo lag. Les. Quote Link to comment Share on other sites More sharing options...
