rekab69 Posted April 18, 2009 Share Posted April 18, 2009 Hi all, I just noticed that the small electric fan just behind the front grill is running all the time, air con switches are off... Any ideas as to why..? Thanks DAve Quote Link to comment Share on other sites More sharing options...
western Posted April 18, 2009 Share Posted April 18, 2009 possibly one of the relays is stuck on. Quote Link to comment Share on other sites More sharing options...
widget Posted April 19, 2009 Share Posted April 19, 2009 possibly one of the relays is stuck on. Or the engine is very hot (as I found out on mine). Quote Link to comment Share on other sites More sharing options...
silvio Posted April 20, 2009 Share Posted April 20, 2009 ...or (provided we are talking about a Td5) you have a fault code logged in your ECU, a fault related with the cooling system (e.g. a wrong data from the coolant temp sensor). In this case you must reset the fault code, with an appropriate diagnostic tool (nanocom, rovacom, T4 and the like...). Quote Link to comment Share on other sites More sharing options...
