Opening the Rear door...
Mark
Anyone know if there is a manual override to get the rear door open on a 3 door softtop freelander?
Or is there a way of taking the handle apart in such a way as to access either the mechanism or the wiring that I can stick 12V up it and get it to release?
ta
Mark
Can't imagine it'd be too difficult, there must be a sensor in the door so all you need is to run the motor the right way when the handle's pulled or the door's closed. If you can work out what the sensors & actuators are doing and post up I'm sure we can work it out.
