Mark Posted April 20, 2009 Share Posted April 20, 2009 Anyone know if there is a manual override to get the rear door open on a 3 door softtop freelander? Or is there a way of taking the handle apart in such a way as to access either the mechanism or the wiring that I can stick 12V up it and get it to release? ta Mark Quote Link to comment Share on other sites More sharing options...
robby71 Posted April 20, 2009 Share Posted April 20, 2009 Can you not just connect the battery leads to the 12v power source ten open the rear door? Quote Link to comment Share on other sites More sharing options...
Llanigraham Posted April 20, 2009 Share Posted April 20, 2009 No manual over-ride, and not that I know off. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 20, 2009 Share Posted April 20, 2009 Can't imagine it'd be too difficult, there must be a sensor in the door so all you need is to run the motor the right way when the handle's pulled or the door's closed. If you can work out what the sensors & actuators are doing and post up I'm sure we can work it out. Quote Link to comment Share on other sites More sharing options...
