sas pinkie Posted April 20, 2009 Share Posted April 20, 2009 Right guys, Managed to get some of those super rare and expensive alloys for my Wolf WMIK. Now this is the first landy that I have ever owned with alloy wheels on (never thought it would happen....) but i owned escort RS turbos in my youth and remember that when putting alloys on them I had to make sure I had wheel bolts with collars so as not to wear through the alloy. Now the question is, does this also stand for Land rover defenders, do I need to get some wheel nuts off of a defender that had alloys on, or do I just bolt em on with my standard wheel nuts? Quote Link to comment Share on other sites More sharing options...
RichardAllen Posted April 20, 2009 Share Posted April 20, 2009 Right guys,Managed to get some of those super rare and expensive alloys for my Wolf WMIK. Now this is the first landy that I have ever owned with alloy wheels on (never thought it would happen....) but i owned escort RS turbos in my youth and remember that when putting alloys on them I had to make sure I had wheel bolts with collars so as not to wear through the alloy. Now the question is, does this also stand for Land rover defenders, do I need to get some wheel nuts off of a defender that had alloys on, or do I just bolt em on with my standard wheel nuts? The LR wheel nuts for my CSW alloys have collars. My suggestion is proper job LR wheelnuts, plenty of copperslip and a breaker bar on the 27mm socket. After all a few bobs for thew right nuts is a lot less than many quids for some new wheels Regards Richard Quote Link to comment Share on other sites More sharing options...
disco tony Posted April 20, 2009 Share Posted April 20, 2009 steel wheels use completely different nuts to alloys. I'm sure you will find pics on e-bay just for reference. Quote Link to comment Share on other sites More sharing options...
western Posted April 20, 2009 Share Posted April 20, 2009 surprised the wheel supplier hasn't mentioned different nuts, Yes you do need the correct items but I've no idea of their part number, could be different length to the standard alloy wheel nuts or at a slim chance they could be exactly the same. Quote Link to comment Share on other sites More sharing options...
SacredDog Posted April 21, 2009 Share Posted April 21, 2009 Right guys,Managed to get some of those super rare and expensive alloys for my Wolf WMIK. Now this is the first landy that I have ever owned with alloy wheels on (never thought it would happen....) but i owned escort RS turbos in my youth and remember that when putting alloys on them I had to make sure I had wheel bolts with collars so as not to wear through the alloy. Now the question is, does this also stand for Land rover defenders, do I need to get some wheel nuts off of a defender that had alloys on, or do I just bolt em on with my standard wheel nuts? Not all Alloys need the collars on the Nuts/Bolts, some wheels have a hardened steel collar built in so they don't wear out the wheels. Colin. Quote Link to comment Share on other sites More sharing options...
sas pinkie Posted April 21, 2009 Author Share Posted April 21, 2009 These look as if they do. I might just phone the manufacturers and check..... Quote Link to comment Share on other sites More sharing options...
markyboy Posted April 21, 2009 Share Posted April 21, 2009 The LR wheel nuts for my CSW alloys have collars. My suggestion is proper job LR wheelnuts, plenty of copperslip and a breaker bar on the 27mm socket.After all a few bobs for thew right nuts is a lot less than many quids for some new wheels Regards Richard I would recommend the use of a torque wrench for any wheel nuts/bolts though not many people adhere to that principle. Overtightening wheel nuts is almost as bad as undertightening them. If you overtighten the nuts/bolts the threads will stretch and lose their clamping efficiency. Fortunately Land Rover wheel studs are very robust and will withstand quite a lot of abuse but it is possible to overdo things. IIRC, the wheel nut torque is around 85 - 95 lb/ft but I would recommend anyone check the manual for their vehicle. Mark. Quote Link to comment Share on other sites More sharing options...
