Defender v8 fan cowling
Just wondering what other people are doing re: the radiator fan cowling on v8 defenders. mine was a 300 tdi converted to 3.9 efi mated to R380 gearbox. it currently has a bodgamatosis 300 tdi cowling that doesn't fit properly or cover enough of the rad. i think this is causing it to run a little on the warm side. what part are you using?
i am thinking of fitting ERR7307 WITH ESR3226 which is the main cowling and top cover piece from a 4.0 efi 50th anniversary,
do you think this would be correct or is there something better out there and preferably cheaper!
Thanks, Steve
Steve.
Is there any reason why you don't just use the standard V8 Defender cowling? I used one on my V8 Defender with LT85 box.
My 130 used to have a deisel engine before I fitted the 4.6....so it must be do-able.
This is the only picture I could find that shows it.post-264-1240388660_thumb.jpg
Regards,
S.
