SpenB Posted April 23, 2009 Share Posted April 23, 2009 Hello all, Very occasionally my handbrake light works, but more often it doesnt. Can someone advise my of the whereabouts of the switch so I can check the wiring and the switch please. Is the switch in your opinions the most likely culprit and/or do these items fail. Thanks, SpenB Quote Link to comment Share on other sites More sharing options...
oakesy Posted April 23, 2009 Share Posted April 23, 2009 Peel back the rubber cover on the bottom of the handbrake and there you will see the trip switch. Also do a search on this website. This subject came up earlier with a diagram and some extra advice. Quote Link to comment Share on other sites More sharing options...
western Posted April 23, 2009 Share Posted April 23, 2009 http://forums.lr4x4.com/index.php?showtopic=1683 my thread on how to fit one in our Tech Archive. Yes I realise you already have the switch wiring fitted, but just for info on switch location. Quote Link to comment Share on other sites More sharing options...
SpenB Posted April 24, 2009 Author Share Posted April 24, 2009 Morning All, Thanks for the replies Oakesy and the Link Western, very much appreciated. Cheers, SpenB Quote Link to comment Share on other sites More sharing options...
Anderzander Posted April 24, 2009 Share Posted April 24, 2009 If you lift the access panel under the centre seat you'll see a small (yellow iirc) wire coming off from the loom and up to the hand brake. Might be worth checking that for damage. Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2009 Share Posted April 24, 2009 wire should be white with a yellow trace. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted April 24, 2009 Share Posted April 24, 2009 Hey I was close! Quote Link to comment Share on other sites More sharing options...
