defender dinky Posted April 24, 2009 Share Posted April 24, 2009 hi all, having trouble with difflock gear stick , but sorted now, while investigating i foung what looks like a filler plug in the housing on the back of it by two wires, removed plug and it was bone dry inside, should this be lubricated at all, oil or grease, put my finger in felt some thing and when pressed main gear lever moved. cheer's wayne Quote Link to comment Share on other sites More sharing options...
reb78 Posted April 24, 2009 Share Posted April 24, 2009 hi all, having trouble with difflock gear stick , but sorted now, while investigating i foung what looks like a filler plug in the housing on the back of it by two wires, removed plug and it was bone dry inside, should this be lubricated at all, oil or grease, put my finger in felt some thing and when pressed main gear lever moved. cheer's wayne Put a picture up.... I think you mean the point where the rod inserts that the main gearlever pushes back and forth to engage gear. You don;t mean the reverse switch do you? - thats the bit with the wires coming out. The 'plug' you mean is in the centre? If this is what i describe, you could grease it. Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2009 Share Posted April 24, 2009 it's not a fill/level plug, just a blanking plug, no lubrication required. Quote Link to comment Share on other sites More sharing options...
defender dinky Posted April 24, 2009 Author Share Posted April 24, 2009 it's not a fill/level plug, just a blanking plug, no lubrication required. hi,thanks, now i can put seats back. wayne Quote Link to comment Share on other sites More sharing options...
