wee_arthur Posted April 24, 2009 Share Posted April 24, 2009 So.... During the removal of the dash i took the front part off and unplugged all connector blocks to get it off. It turned out it was too tight and i couldnt see any other connecors and i thought ill just unplug the connectors on the dials and i'll see the wiring diagram. Now im looking at the diagram and cant tell what wire goes where. I now have the big connector which i know connects to the dash dials with a few plugs on them that i dont know where they go does anyone know where i would get a detailed wiring diagram of the dash connections? thanks Quote Link to comment Share on other sites More sharing options...
wee_arthur Posted April 24, 2009 Author Share Posted April 24, 2009 Pictures.... Anyone have an idea as to what goes where?? I need the wires that go into the dials: Do these have something to do with it?? Just an overall picture: Thanks again Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2009 Share Posted April 24, 2009 gauge lighting is red/white trace wire temp gauge is green/blue wire fuel gauge is green/black trace plain green wire is gauge 12volt power feed the 2 white connectors only fit one way, so these cannot be fitted incorrectly. the plain black wire is earth & fits to the centre post of each gauge/speedometer. the end terminls cannot be incorrectly fitted at the gauges as the terminals will only except their mate. looking at the 1st photo, which gauges are fitted starting at the speedo end of the instrument pack ? it'll help me give you the right info hth the rear wiper wires do a search as this was covered very recently. Quote Link to comment Share on other sites More sharing options...
wee_arthur Posted April 24, 2009 Author Share Posted April 24, 2009 gauge lighting is red/white trace wiretemp gauge is green/blue wire fuel gauge is green/black trace plain green wire is gauge 12volt power feed the 2 white connectors only fit one way, so these cannot be fitted incorrectly. the plain black wire is earth & fits to the centre post of each gauge/speedometer. the end terminls cannot be incorrectly fitted at the gauges as the terminals will only except their mate. looking at the 1st photo, which gauges are fitted starting at the speedo end of the instrument pack ? it'll help me give you the right info hth the rear wiper wires do a search as this was covered very recently. Speedo ...... Fuel ..... Water temp..... Battery in that order (i have 1 black and 1 green wire left but these are circular female couples) (and there are heavier wires one is black and one is brown which are also circular female couples) sorry im apsolut rubbish at wiring Quote Link to comment Share on other sites More sharing options...
SacredDog Posted April 24, 2009 Share Posted April 24, 2009 (and there are heavier wires one is black and one is brown which are also circular female couples) I'm not certain but I think Blank is Battery -ve and Brown permanent +12v but I don't think they are used behind my Dash (94MY V8). Colin. Quote Link to comment Share on other sites More sharing options...
western Posted April 25, 2009 Share Posted April 25, 2009 Speedo ...... Fuel ..... Water temp..... Batteryin that order (i have 1 black and 1 green wire left but these are circular female couples) (and there are heavier wires one is black and one is brown which are also circular female couples) sorry im apsolut rubbish at wiring within the wiring that sits behind the instrument pack you should find a 'Bullet' connecter sleeve, maybe grey or black in colour, with Brown [12 volt feed] & black [earth] wires, match these to the ones on the wiring you took photo's pf above. the other green is a 12v feed so connect that to a matching green in the main wiring & connect the gauges as identified above then everything should be working. Quote Link to comment Share on other sites More sharing options...
wee_arthur Posted April 26, 2009 Author Share Posted April 26, 2009 within the wiring that sits behind the instrument pack you should find a 'Bullet' connecter sleeve, maybe grey or black in colour, with Brown [12 volt feed] & black [earth] wires, match these to the ones on the wiring you took photo's pf above. the other green is a 12v feed so connect that to a matching green in the main wiring & connect the gauges as identified above then everything should be working. Thanks for all the help mate Quote Link to comment Share on other sites More sharing options...
