mrgsxr Posted April 25, 2009 Share Posted April 25, 2009 I have a w reg 2000 freelander (45,000 miles)and it has developed a judder/banging at rear wheels when turning at junctions etc(under power)and sometimes pulling away,strange thing is it does not do it all the time,i think it does it more with passengers aboard,i have had a quick read but not sure what to think! Its not the rear diff mounts i undid the front one and its ok,checked the left and right ones with torch and they looked ok aswell,i thought they would be as these were changed around 6 months ago,I also did the vcu tippex test and the vcu is also ok just hope its not the ird any advice would ge great thanks Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 26, 2009 Share Posted April 26, 2009 CV joints? I would also have said the diff mounts but if you have checked those I guess not. Quote Link to comment Share on other sites More sharing options...
mrgsxr Posted April 26, 2009 Author Share Posted April 26, 2009 i thought it was the suspension,somebody else said cracked chassis or Sub frame mount broken aint got a clue where to look on vehicle for those problems. Quote Link to comment Share on other sites More sharing options...
Olley Posted April 27, 2009 Share Posted April 27, 2009 i thought it was the suspension,somebody else said cracked chassis or Sub frame mount broken aint got a clue where to look on vehicle for those problems. When i turn on full lock the entire vcu housing rotates with the drive shafts. This causes banging and juddering noises. I discovered this by painting a mark on the vcu and driving in a straight line, the mark didn't move. I then turned full lock drove round in a circle, heard the banging, the mark on the vcu had moved. I haven't solved it , i just live with it. Quote Link to comment Share on other sites More sharing options...
mrgsxr Posted April 28, 2009 Author Share Posted April 28, 2009 Its mainly occuring when i turn into right hand junctions and the passenger side rear wheel judders or it does it slightly when pulling away the same side i think. Quote Link to comment Share on other sites More sharing options...
Blippie Posted May 5, 2009 Share Posted May 5, 2009 If the front rear diff mount is definately OK, then my fingher points at the rear subframe. Cheers Blippie Quote Link to comment Share on other sites More sharing options...
mrgsxr Posted May 23, 2009 Author Share Posted May 23, 2009 If the front rear diff mount is definately OK, then my fingher points at the rear subframe.Cheers Blippie any pics or information as to what im looking for on the rear subframe? (i have changed diff mounts to test and still the same) Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 24, 2009 Share Posted May 24, 2009 I doubt it would be the rear subframe - chunky thing that it is. This thread will help perhaps for mounting points, likely problems, pretty pictures, etc http://forums.lr4x4.com/index.php?showtopic=36379 Les Quote Link to comment Share on other sites More sharing options...
