David Sparkes Posted April 26, 2009 Share Posted April 26, 2009 As the subject says, there is a variant of the 'sticky out' Series 2 door hinge that has an ear included in the casting. There is even an ear 'ole in which a mirror is mounted. This hole is ~5/8" diameter, which is much larger than a standard Series mirror arm (DA2128 or 262658). If it helps the hinges are 346376 (RH) and 346377 (LH). Pictures for these and the DA2128 can be found on the LRSeries.com site. 262658 can be found on Land Rover Orphanage. The search is for a mirror arm which fills the hole, can someone help? Thanks. Quote Link to comment Share on other sites More sharing options...
