gali Posted April 26, 2009 Share Posted April 26, 2009 Is there any experience with the rear oldman springs? Can you guys let me know how much lift I will gain while using the MD size on a D110 soft-top? Are they to strong for the car? Do they feel comfortable with around 200Kg weight loaded on the back of the vehicle? Gali. Quote Link to comment Share on other sites More sharing options...
western Posted April 26, 2009 Share Posted April 26, 2009 got some OME springs on my 11CSW, carries around 400kg of rally recovery kit in the back & the ride/handling is brill. have a look at http://members.shaw.ca/jbarge/springinfo.html#OME to see the dofferent load carrying rates, the 763 or 762 may do the job for you, it'll raise the rear about 1 to 1.5 inches too. Quote Link to comment Share on other sites More sharing options...
gali Posted April 26, 2009 Author Share Posted April 26, 2009 got some OME springs on my 11CSW, carries around 400kg of rally recovery kit in the back & the ride/handling is brill. have a look at http://members.shaw.ca/jbarge/springinfo.html#OME to see the dofferent load carrying rates, the 763 or 762 may do the job for you, it'll raise the rear about 1 to 1.5 inches too. thanks. but 763 & 762 are for D90, i'm on a D110 soft top. i assumed i should have 752 or 755 according to: http://www.oldmanemu.com/item.html?pid=1920 https://www.expeditionexchange.com/ome/indexsprings.htm (at the bottom of the page). Gali. Quote Link to comment Share on other sites More sharing options...
western Posted April 26, 2009 Share Posted April 26, 2009 they ill still work with your 110. the 752 are light duty for 110 & the 755 would probably be to hard when no load carried. Quote Link to comment Share on other sites More sharing options...
gali Posted April 26, 2009 Author Share Posted April 26, 2009 they ill still work with your 110.the 752 are light duty for 110 & the 755 would probably be to hard when no load carried. it doeasnt seems like since the D90's spring diameter is smaller then the D110. Quote Link to comment Share on other sites More sharing options...
western Posted April 26, 2009 Share Posted April 26, 2009 OK, seems your only choice is the 752 or 755 then, I have the 754 at the back & when empty my 110 is a bit hard at the rear. Quote Link to comment Share on other sites More sharing options...
gali Posted April 27, 2009 Author Share Posted April 27, 2009 i'll try within few days & post a Pic. thanks alot. Quote Link to comment Share on other sites More sharing options...
