gwyn lewis challenge rear shock mounts
SCHREIBER
Has anyone got a pair of these they can measure the distance between the original bolt holes and the new shock mounting hole, as unfortunatly gwyn's mounts won't fit my 90, as they would sit proud, ontop of my roll cage mount :( so I'm going to have to weld some 6mm plate to the chassis instead.
Chris :)
If you want me to compare them to standard position I'll have to do it as I'm fitting them and I've a few more bits to buy before I do that ....
I will do - but someone may be able to do it quicker if you're in a rush?
I only need to know the measurment between the mounting holes and the new shock mounting hole in the shock mount(the one that gives most articulation on your mounts)
Cheers
Chris
