mrtash Posted April 26, 2009 Share Posted April 26, 2009 hi, we have purchased a second hand discovery today the disco is on a L plate, beneith the passenger seat is 5 cd changer, because the vehicle is a little old there was little in the way of operator instuctions, can anyone give us a few starters on how to get the cd player to work, the buttons to the right of the steering wheel for the volume to the radio function so we are optimistic the cd changer will also work. Thanks Pete Quote Link to comment Share on other sites More sharing options...
Orange Posted April 27, 2009 Share Posted April 27, 2009 Any ideas on make and model? Is it a standard LR fitment, or is it an aftermarket upgrade type affair? Quote Link to comment Share on other sites More sharing options...
nicedayforit Posted April 27, 2009 Share Posted April 27, 2009 hi, we have purchased a second hand discovery today the disco is on a L plate, beneith the passenger seat is 5 cd changer, because the vehicle is a little old there was little in the way of operator instuctions, can anyone give us a few starters on how to get the cd player to work, the buttons to the right of the steering wheel for the volume to the radio function so we are optimistic the cd changer will also work. Thanks Pete If you are stuck I have the original LR handbook for your vehicle which contains the CD operating instructions. If you wish to pm me your email address and I will see if I can get them to you. You are lucky any of the console buttons still work they should have expires long ago , mine have. Quote Link to comment Share on other sites More sharing options...
bigbeast Posted April 27, 2009 Share Posted April 27, 2009 dos the unit work (ie, radio) but dosent play cd's? if so the easiest way to eliminate problems would be to pull out the unit from the dash and see if everythings attached in the back, the disk changer will more than likely have one feed coming from the back of it to the back of the unit and possibly a seperate (or combined) on/off power supply from the unit..failing that the changer may be knackered..good luck Quote Link to comment Share on other sites More sharing options...
