Grant. Posted April 26, 2009 Share Posted April 26, 2009 Hi All, Between 40 and 70 my defender has a horrible vibration,its worse on overrun, even with the clutch pressed. I have checked the wheel bearings, not that much play, Also checked the props, no play there, any other suggestions!!?? Thanks in advance Grant Quote Link to comment Share on other sites More sharing options...
Aragorn Posted April 26, 2009 Share Posted April 26, 2009 swivel preload is a common one for this, also worth checking all the bushes in the suspension... Quote Link to comment Share on other sites More sharing options...
western Posted April 26, 2009 Share Posted April 26, 2009 wheel balance, may have lost a balance weight off one or more wheels. Quote Link to comment Share on other sites More sharing options...
Grant. Posted April 26, 2009 Author Share Posted April 26, 2009 Thanks guys, forgot to say, also just fitted wheel spacers and 2 inch lift, will the preloads need to be adjusted as spacers have been fitted? Quote Link to comment Share on other sites More sharing options...
western Posted April 26, 2009 Share Posted April 26, 2009 may be a slight mismatch between the hubs/spacers, are you 100% sure the spacers are fitted on dead square to the hub. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted April 26, 2009 Share Posted April 26, 2009 Grant, did you take your props off to check the UJs. Most vibrations after a lift come from the Ujs as they will be operating in a tighter arc which will soon find a out a 50/50 UJ. HTH Mo Quote Link to comment Share on other sites More sharing options...
LittleBlue88 Posted April 26, 2009 Share Posted April 26, 2009 ^^^^^^^As Mo says,props are prob unhappy....get underneath and kiss them better Quote Link to comment Share on other sites More sharing options...
Grant. Posted April 26, 2009 Author Share Posted April 26, 2009 Kidokes, Checked the wheel, a line of weights was missing!! Changed the wheel over with the spare, seems better, however when the engine is breaking there is still a groan coming up, sounds like from the back, this causes a reverb still, but the general shake is reduced alot!! Looked at the props. they both seem very content under there with no real play at all!! any more thoughts? Thanks again Grant Quote Link to comment Share on other sites More sharing options...
jason110 Posted April 26, 2009 Share Posted April 26, 2009 panhard rod bushes - made my vibrate like a b**** HTH jase Quote Link to comment Share on other sites More sharing options...
KKMobile Posted April 27, 2009 Share Posted April 27, 2009 My 90 used to drive ok until i fitted a 2inch lift!! then had same sort of problem as you are having!! Spoke with a few freinds who had lifted their's aswell & they had the same trouble?? turned out to be probshafts! even with new ones it still done it!! contacted driveline & oredered some wide agle'd one's & all vibrations stopped as soon as they sere fitted!! Gave him the measurements from flange to flange wednesday afternoon & they were both delivered on Friday morning! They've been on now for about a year and still no trouble's!! hope this help's if you want to ring them their number is 01524 382262 very helpful when they done mine & price was reasonable to!! Quote Link to comment Share on other sites More sharing options...
Grant. Posted April 27, 2009 Author Share Posted April 27, 2009 Hi Guys the props don't look marked, as in the yokes don't look like they are hitting.... i will look in more detail when i can, however they looked fine! Any other thoughts before i lose my mind? Thanks Quote Link to comment Share on other sites More sharing options...
Grant. Posted April 29, 2009 Author Share Posted April 29, 2009 Ok, my props look fine, the front one is nearly new, so no play in it at all one of the rears has a teeny weeny bit of play, but literally nothing!! The shake, vibration, groaning only is bad on overrun from 70-55, its not constant it will be for a couple of seconds then it will disappear, if you give it a bit of throttle you can keep the noise going for a while!! Any more thoughts? Thanks Grant Quote Link to comment Share on other sites More sharing options...
fender1234 Posted April 29, 2009 Share Posted April 29, 2009 i would take a prop off and go for a drive so you can rule out whether it coming from front or back, it also might be easier to check the props when they are off HTH Quote Link to comment Share on other sites More sharing options...
Grant. Posted April 29, 2009 Author Share Posted April 29, 2009 Thanks will try that! Could it be a diff noise? As I said i checked the wheel bearings, there didn't seem to have any play..... Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted April 29, 2009 Share Posted April 29, 2009 Hello mate I had the same sort of vibration/ noise between 40-70 mph it would happen on the over run and like you if i touched the throttle i could make it last longer !! After checking everything prop/uj's etc i reaslise that the diff bearing had a lot of play so i changed the diff and the noise has gone ! I have been told that like yourself a 2" lift puts many parts under extra stress and wear in diff bearing is quite a common fault. Hope this helps Chris Quote Link to comment Share on other sites More sharing options...
Grant. Posted April 29, 2009 Author Share Posted April 29, 2009 Hello mate I had the same sort of vibration/ noise between 40-70 mph it would happen on the over run and like you if i touched the throttle i could make it last longer !! After checking everything prop/uj's etc i reaslise that the diff bearing had a lot of play so i changed the diff and the noise has gone ! I have been told that like yourself a 2" lift puts many parts under extra stress and wear in diff bearing is quite a common fault. Hope this helps Chris Hi Chris, I admit, i had a similar issue with my 90 (didnt really think it could be the same!!), until i went in some more water and the diff bearing disintigrated!! spat the ball bearings into the diff gearing as I was just coming out the other side of a ford, and destroyed all the teeth I was wondering if it was that, however it sounds plausible! was it your front or rear diff?? ( mine seems to come from the rear more so...) I have a Salisbury rear axle, are they all the same splineage? whether there drum or disk Quote Link to comment Share on other sites More sharing options...
mudmuncher Posted April 29, 2009 Share Posted April 29, 2009 Hi Mate Mine was the rear diff its a standard axle and diff, it was strange because the diff only had a very small amount of play in the bearing and to be honest i thought there was no chance a small amount of play could cause all that vibration and noise !!! But it did i replaced the diff (second hand one ) and the noise has totally gone now !!! Chris Quote Link to comment Share on other sites More sharing options...
Grant. Posted April 29, 2009 Author Share Posted April 29, 2009 lovely, thanks!! Now, since I am suspicious of the rear diff, I need some advice on the rear diff!! Its a Salisbury, and the problem is, i've heard, and seen that to remove the Salisbury diff, you need a diff spreader!(????) According to the workshop manuals that is... Can anyone shed some light on how to change a Salisbury diff??? Looked in the tech archives, and had no luck!! Thanks Grant Quote Link to comment Share on other sites More sharing options...
Grant. Posted April 30, 2009 Author Share Posted April 30, 2009 anyone able to shed light on changing a salisbury diff??? PLEEASE!!?? Thanks Grant Quote Link to comment Share on other sites More sharing options...
western Posted April 30, 2009 Share Posted April 30, 2009 this might help similar subject about pulling a Salisbury diff without a case strecher. Quote Link to comment Share on other sites More sharing options...
forkrentfitter Posted April 30, 2009 Share Posted April 30, 2009 hi grant,if you have a problem with a salisbury it is not a 5 minute job to pull out and check,they also are a bit of a pain to set up on reassembley.how is the hybrid coming along? Quote Link to comment Share on other sites More sharing options...
Grant. Posted April 30, 2009 Author Share Posted April 30, 2009 hi grant,if you have a problem with a salisbury it is not a 5 minute job to pull out and check,they also are a bit of a pain to set up on reassembley.how is the hybrid coming along? LOL slowly!!! Ive driven it, and im going to do more work and get some piccis up this weekend, been away for a month!! I promise i will this weekend though, including the pictures of your handy work with the wheel wells!! Back to the diff though, could the noise, be coming from the prop, cos i never thought props made noise when they went, when my front one went, i heard nothing till it went bang!! Thanks again ( cheers Chris!!) Quote Link to comment Share on other sites More sharing options...
Grant. Posted April 30, 2009 Author Share Posted April 30, 2009 this might help similar subject about pulling a Salisbury diff without a case strecher. Oh, and thanks Western, that will help if the worst comes to the worst!!! Quote Link to comment Share on other sites More sharing options...
