Orgasmic Farmer Posted April 27, 2009 Share Posted April 27, 2009 If anyone has a 200 tdi filter assembly from a Discovery in shed I am after the ID diameter of the pipe that runs from the plastic pipe from the filter to the intercooler, specifically at the filter box end (though I think it is the same). Also if anyone has a spare plastic bit that joins the filter box to this pipe I am looking for one for a project. Thanks Mark Quote Link to comment Share on other sites More sharing options...
Lars L Posted April 27, 2009 Share Posted April 27, 2009 The hose from the airbox plastic thingy to the turbocharger is 2,5"/67 mm. Quote Link to comment Share on other sites More sharing options...
Lars L Posted April 27, 2009 Share Posted April 27, 2009 The hose from the airbox plastic thingy to the turbocharger is 2,5"/67 mm. 2,5" is not 67 mm, rather 64... Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted April 27, 2009 Author Share Posted April 27, 2009 Thanks for that Lars. Now to order some pipe! Quote Link to comment Share on other sites More sharing options...
Gremlin Posted April 27, 2009 Share Posted April 27, 2009 If anyone has a 200 tdi filter assembly from a Discovery in shed I am after the ID diameter of the pipe that runs from the plastic pipe from the filter to the intercooler, specifically at the filter box end (though I think it is the same). Also if anyone has a spare plastic bit that joins the filter box to this pipe I am looking for one for a project.Thanks Mark 200tdi air cleaner inlet and outlet are 3" while turbo inlet is 2.5", just ordered some hoses................. G Quote Link to comment Share on other sites More sharing options...
Lars L Posted April 27, 2009 Share Posted April 27, 2009 You're probably quite right there, Mr Gremlin. But the question was from the plastic elbow that sits on the box... Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted April 27, 2009 Author Share Posted April 27, 2009 DOH, I meant filter box to Turbo!! Anyway it is sorted now so no longer a problem. Cheers Mark PS You are correct that the box outlet is 3" but the plastic elbow is much smaller where it joins the pipe to the turbo, Infact the internal diameter of the plastic (which is quite thick) is probably about 57mm. So I have done like you and gone straight to the box and ordered up appropriate pipe and a reducer from 3" down to 2.5" Quote Link to comment Share on other sites More sharing options...
