Momentary waterproof switch
Maybe something simonr at X-Eng or MUD-UK could help with, as providers of Carling switches. Just ordered some bits from both companies today and had great service.
Alternatively, I think your looking into Marine/Boat supplies.##
Mick.
RS and Farnell both do them. I prefer the push switches myself as they're far less prone to physical damage than a toggle switch. Just look for IP67 rated items and it'll be fine on the outside of a motor as it's totally sealed from dust and waterproof to 1m deep. IP68 gives better depth if you're thinking of turning into a submarine for any length of time.
Toggle switch...
http://uk.farnell.com/tyco-electronics/awt...-mom/dp/1436246
I use one of these...
http://uk.farnell.com/itw-switches/76-9410...equestid=305814
and
http://uk.farnell.com/itw-switches/76-9410...09281?in_merch=
Regardless of which type you have, make sure you have a master switch in the cab to enable/disable the external controls. Mine only work when the ignition is on and I've enabled them with a switch on the dashboard.
