What tool is needed for this?
muddyplugger
I am going to delve into the mystery of replacing an ABS wheel sensor
You don't need to take the brakes off to do the wheel sensor. Not long done mine and you don't even need to take the wheel off.
It's a 10minute job, 1 screwdriver, a pair of pliers and a small hammer.
Undo the sensor from where it goes into the modulator on the inner wing.
Lay under the vehicle, unclip the cable from its clip up by the chassis on its way to the inner wing.
Pliers, pull the sensor out of the back of the hub.
Check the copper/brass thing didn't come out of the hub, push the new sensor in.
Replace cable into clip, plug into modulator.
Bingo! :D
Best of luck with it.
I await in anticipation...
Unfortunately, anticipation wasted bud. :(
My apologies, method as described was indeed Tdi.
I'll get hold of my mate Andy (knower of all things) and ask him if you can do the same on the Disco 2, post back tomorrow.
Dunc
According to Andy (he works at local L/R dealer) it should go just the same as when we did my 300Tdi.
Spoke to him this morning.
Best of luck
Dunc.
Best of luck
Dunc.
Cheers Mate :D
I've just got to get a new fuel pump fitted, then I can get it in the garage! Its not nice doing this stuff in the rain. It waters my beer down!! ;)
