92a Posted April 29, 2009 Share Posted April 29, 2009 As above ,I have never seen my one move, the silicon hoses swell up but never seen rod move or do you have to really rev it for a long time? Help please I dont want to blow it up! thankyou Angus Quote Link to comment Share on other sites More sharing options...
stageonesimmo Posted April 29, 2009 Share Posted April 29, 2009 You cant build up enough boost to make it move stood still - you'd need to be under the bonnet as its doing full tilt up a hill in 3rd or 4th gear to see it work! Not recommended! Stop worrying about it and tackle the rust instead! Quote Link to comment Share on other sites More sharing options...
Davecrx Posted April 30, 2009 Share Posted April 30, 2009 Your soon find out if it wasn't working.. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted May 1, 2009 Share Posted May 1, 2009 Check the pivot by romoving the link - it should turn freely. Mine was VERY stiff and was jammed part way open :0 , but a few shots of stuff to clean the carbon from the shaft/bearing and it freed up nicely. If I recall correctly, for testing that the actuator moved I SLOWLY AND CAREFULLY (risk of explosion!) moved a blowing airline towards the inlet until it moved. Not proof it's ok, but at least shows it's not seized. Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted May 1, 2009 Share Posted May 1, 2009 As above ,I have never seen my one move, the silicon hoses swell up but never seen rod move or do you have to really rev it for a long time? Help please I dont want to blow it up! thankyou Angus I sharp stab of the throtte should see it move a bit ( prob achieve about 0.2 - 0.2 bar). But you won't see it move much. Best things to do is fit a boost guage to check pressure and then make sure linkage is free as threesheds said. Quote Link to comment Share on other sites More sharing options...
