robert Posted April 30, 2009 Share Posted April 30, 2009 My vehicle is a 2003 Series II Disco TD5 manual. I am asking if anyone knows the procedure for entering the security code. I have the code. Tomorrow I intend disconnecting the battery so I will need to re-activate the radio. Unfortunately the radio instructions did not include a section on entering the code. The radio/CD player has 6 buttons on the front, a single CD slot at the top and vol/bass/reble control on left with band/menu/search on right. Beside the CD slot, on its left is the RDS and on its right is the traffic info button. It has no brand or model name however I have included a photo of the unit in the attachment Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 30, 2009 Share Posted April 30, 2009 Most either use the preset buttons to set each digit (e.g. if the code is 3529 press preset 1 3x, preset 2 5x etc ) or they use the up/down buttons to set the digit and the 1 preset to store. I've not seen a radio like that though. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted April 30, 2009 Share Posted April 30, 2009 Mine is an old cassette one - but on that you just push the numbered buttons. Quote Link to comment Share on other sites More sharing options...
scrumps Posted May 1, 2009 Share Posted May 1, 2009 Mine is an old cassette one - but on that you just push the numbered buttons. Hi, The radio you have is the "VISTEON" unit fitted in the last D2's and some Freelanders. The link below will take you to the code instructions but beware of the 12 tries rule or it's goosed. Regards Scrumps P.S. If someone can make it "clicky" please!!! Quote Link to comment Share on other sites More sharing options...
robert Posted May 13, 2009 Author Share Posted May 13, 2009 Hi,The radio you have is the "VISTEON" unit fitted in the last D2's and some Freelanders. The link below will take you to the code instructions but beware of the 12 tries rule or it's goosed. Regards Scrumps P.S. If someone can make it "clicky" please!!! Thank you all for your help with this. I eventually found that it worked by toggling the relevant number using the first 4 numbered buttons. The code is entered by pushing the > symbol on top of the RHS menu button Rob Quote Link to comment Share on other sites More sharing options...
