CJRH Posted April 30, 2009 Share Posted April 30, 2009 I've got an issue with the banjo bolt on the power steering pump. The banj bolt I have the thread is too small. I've got a connecting pipe that happens to have the correct size thread on it, the part number on the connecting pipe is NTC8861. I need the correct sise banjo bolt, any ideas? Chris Quote Link to comment Share on other sites More sharing options...
western Posted April 30, 2009 Share Posted April 30, 2009 NTC8861 pipe steering box to reservior should screw straight into the steering box. banjo RTC5674 SEALING WASHER X 2 FOR BANJO RTC5675 as for the actual banjo bolt, looks like it only available with a new pump as here, this one is also used on pre 300Tdi vehicles/engines Quote Link to comment Share on other sites More sharing options...
CJRH Posted April 30, 2009 Author Share Posted April 30, 2009 Cheers for that, not sure why I've ended up with an odd size banjo bolt............. Chris Quote Link to comment Share on other sites More sharing options...
western Posted April 30, 2009 Share Posted April 30, 2009 was that banjo bolt fitted to the pump or is it a spare just lazing about waiting for a home. Quote Link to comment Share on other sites More sharing options...
CJRH Posted April 30, 2009 Author Share Posted April 30, 2009 It came out of a Landrover power steering pump which I thought was from a 200tdi but obviously it wasn't!! CHris Quote Link to comment Share on other sites More sharing options...
western Posted April 30, 2009 Share Posted April 30, 2009 has the pump got a part number on it ? if so I should be able to find out which engine/vehicle it came off. is your engine a Discovery 200Tdi ? the Defender 200Tdi uses the same pump as a TD NTC9070 this one has a large nut on the body for one pipe to screw in to & a curved stub pipe on the rear face for the 2nd hose to slide over & secured by a jubilee clip. Quote Link to comment Share on other sites More sharing options...
CJRH Posted May 1, 2009 Author Share Posted May 1, 2009 OK, I've got to the bottom of it now. The power steering pipes were bought afterwards and have a banjo bolt fitting that is wrong. I’ve managed to get the correct screw in fitting now and I’ve had the pipes made up at a local hydraulic company. Thanks for your help with this. Chris Quote Link to comment Share on other sites More sharing options...
western Posted May 1, 2009 Share Posted May 1, 2009 no probs, good to know you managed to get sorted Quote Link to comment Share on other sites More sharing options...
