Hybrid_From_Hell Posted May 1, 2009 Share Posted May 1, 2009 or rather .................. Whilst having a good 'lookie and measure up' last night I found my initial plans may be a non runner What I am interested in is for those here with winches, and either 90 or RR chasiised 90 hybrids, could you please look at the distance at the front (the "overhang") and grab a tape measure : ie At the end of the 90 chassis, - the front bit with the rubber plug in it - measure from here to the furthest sticky out point of the winch assembly (EX FAIRLEAD) and post up the length and if your really kind a pic too ?? If you are unable to "See" the end of the chassis bit as its maybe "hidden" within the bumper then as plan B could you do the same measurement, but use the centre point of one of the two vertical bumper bolts as the datum, but FFS tell me which of the 2 datums - end of chassis vs centre of bolt head you have used Ta Muchly muchly Nige Quote Link to comment Share on other sites More sharing options...
SteveG Posted May 1, 2009 Share Posted May 1, 2009 measure with rubber plug removed or not?? ;) Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 1, 2009 Author Share Posted May 1, 2009 measure with rubber plug removed or not?? ;) I can suggest where you could pop the rubber plug temp if you remove it to measure Either way, just advise which datum point ie chassis end or bolts and mit or mit out plug Nige Quote Link to comment Share on other sites More sharing options...
bishbosh Posted May 1, 2009 Share Posted May 1, 2009 Nige, What so worried about what everyone else has? It's not as if you're not accustomed to being "different" Quote Link to comment Share on other sites More sharing options...
stewy1984 Posted May 1, 2009 Share Posted May 1, 2009 minus the dumb irons, from the front of the chassis (excluding fairlead) mine sticks out 40mm, but sits on top of the chassis. Quote Link to comment Share on other sites More sharing options...
Dave W Posted May 1, 2009 Share Posted May 1, 2009 From the end of the chassis to the front face of the winch mount it's 60mm on mine - 8274 mounted above the chassis. I had to modify the front cross member to achieve that, the rear of the 8274 sits inside the cross member. Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted May 1, 2009 Share Posted May 1, 2009 Mine sticks out 30mm past the front of the chassis (the bit you talk about isn't there any longer!) and sits on top. I had to move the rad back quite close to the steering box to do this. got some pics on the home pc so I'll post them later. Quote Link to comment Share on other sites More sharing options...
upnover4x4 Posted May 1, 2009 Share Posted May 1, 2009 Therea approx 2" of free space between where the rad would be mounted as std & the steering box that you could possibly move the rad housing back to gain a bit of extra room. I moved my rad back closer to the steering box to gain that little extra. I ended up remaking a d44 bumper to allow the winch to sit back further but was a bit of a headache. Theres very little space left between the rad & winch(8274) now and could probably do with a drum protector. The front of the bumper now sit approx 3" in front of the chassis rail.DOnt know how that compares with others but has made for a good approach angle. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted May 1, 2009 Share Posted May 1, 2009 From the end of the dumb iron to the most sticky outy bit is 140mm thats with no cutting out of grills etc for winch, if you wer to cut the grill u could recess the winch about 40/50mm further at a guess. It gives me plenty of approach for what i do Quote Link to comment Share on other sites More sharing options...
Les Brock Posted May 1, 2009 Share Posted May 1, 2009 From the centre of the mounting bolts 120mm Front cross member was moved as far back as it would go to the power steering box when I had the H14 in, and the front legs were cut back Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted May 3, 2009 Share Posted May 3, 2009 Mine sticks out 30mm past the front of the chassis (the bit you talk about isn't there any longer!) and sits on top. I had to move the rad back quite close to the steering box to do this. got some pics on the home pc so I'll post them later. Was built in a rush before an event with a view to building a tidy one but as always seem to have not got round to it yet. The folded plates did arrive a few weeks ago so it might happen soon. Gives an idea of positions tho! Quote Link to comment Share on other sites More sharing options...
