maxxTraxx09 Posted May 1, 2009 Share Posted May 1, 2009 Manage to find the problem with the axle after stripping down the hold thing the CV joint splines were worn on both the CVJ & drive flange, now I need to know how to get the shaft out of the CV joint...do you have to press it out? Thanks MaxxTraxx Quote Link to comment Share on other sites More sharing options...
tychoS Posted May 1, 2009 Share Posted May 1, 2009 Manage to find the problem with the axle after stripping down the hold thing the CV joint splines were worn on both the CVJ & drive flange, now I need to know how to get the shaft out of the CV joint...do you have to press it out?Thanks MaxxTraxx The workshop manual has a drawing of a man hammering the cv off the shaft, while the shaft is held in a vice. There's a little ring in a grove at the end of the shaft. This has to be compressed in order to withdraw the shaft from the cv. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted May 1, 2009 Share Posted May 1, 2009 Normally, you just tap it off. Sometimes the clip gets jammed in there are you need some serious brute force. Be careful if you are keeping the CV as they are brittle and will crack if hit sharply. Quote Link to comment Share on other sites More sharing options...
JST Posted May 1, 2009 Share Posted May 1, 2009 it should just knock off with a gentle blow... Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 1, 2009 Share Posted May 1, 2009 it should just knock off with a gentle blow... ...and if a gentle blowing at it doesn't do it pick up a hammer and give it a whack Nige Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 1, 2009 Share Posted May 1, 2009 The cv joint and shaft have to be in a straight line in order to seperate them the easiest. Don't hit the cup, but rather the inner ball track. This puts pressure directly on the clip that retains the shaft, and hopefully 'shocks' the clip into it's groove to allow the two to seperate. Les. Quote Link to comment Share on other sites More sharing options...
