jfkm Posted May 2, 2009 Share Posted May 2, 2009 Hello. Still a question. I want to install the PRRT kit on my Freelander . I bought the kit Land Rover as seen on this subject: http://www.unicyclist.com/gallery2/main.ph...2_itemId=559552 But I do not understand why the gentleman who is the subject autor changed his kit? Is this the mounting for a Freelander? Can someone tell me how my mechanic must install my kit correctly ? Thank you for your help. JF Sorry for my English, using a traducer. Quote Link to comment Share on other sites More sharing options...
western Posted May 2, 2009 Share Posted May 2, 2009 the attached file shows & says the kit is for a 1.8 petrol engine Freelander, I'm not sure why you feel the engine needs this kit. Quote Link to comment Share on other sites More sharing options...
jfkm Posted May 3, 2009 Author Share Posted May 3, 2009 the attached file shows & says the kit is for a 1.8 petrol engine Freelander, I'm not sure why you feel the engine needs this kit. Because I have a Freelander 1L8 ... But I am not sure which vehicle the man equiped into the attached file, and if it's a Freelander, why he modify his PRRT kit ... Because he take a origin PRRT Kit for a Freelander, BUT he explain how to modify it.... My question is to understand if i have to modify my PRRT kit to put on my Free 1L8. I do not understand English well enough to understand exactly what he says. Thanks. JF Quote Link to comment Share on other sites More sharing options...
jfkm Posted May 3, 2009 Author Share Posted May 3, 2009 I have a 1L8 Freelander, and I want to install this kit PRRT. But I do not understand why on the link, the guy modifies the PRRT kit Land Rover Before installing ... Is this really on a Freelander he installs ?? I do not understand enough English to understand his tuto ... Thanks. JF Quote Link to comment Share on other sites More sharing options...
q-rover Posted May 4, 2009 Share Posted May 4, 2009 I'm not sure why you feel the engine needs this kit. It improves the likelyhood of the engine living a long and fruitfull life, rather than blowing a headdgasket and melting itself. Quote Link to comment Share on other sites More sharing options...
viorelluta Posted May 6, 2009 Share Posted May 6, 2009 The author of the article says that the installation described is done on a Rover 200, which is probably the reason to modify some parts (lack of space, compared to a Freelander). I would not do such modification by myself, as cooling is critical. But I am not a mechanic. Viorel JF: L'auteur de l'article dit que l'installation décrite est faite sur un Rover 200, qui est sans doute la raison de modifier quelques parties (le manque d'espace, comparé à un Freelander). Je ne ferais pas une telle modification moi-même, comme le refroidissement est critique. Mais je ne suis pas un mécanicien. J'utilisais aussi un traducteur comme mon français est mauvais - vérifient ce site: http://www.translation2.paralink.com/ Viorel Quote Link to comment Share on other sites More sharing options...
pinkbeef Posted May 6, 2009 Share Posted May 6, 2009 Hello. Still a question. I want to install the PRRT kit on my Freelander . I bought the kit Land Rover as seen on this subject: http://www.unicyclist.com/gallery2/main.ph...2_itemId=559552 But I do not understand why the gentleman who is the subject autor changed his kit? Is this the mounting for a Freelander? Can someone tell me how my mechanic must install my kit correctly ? Thank you for your help. JF Sorry for my English, using a traducer. If you have a Freelander 1.8, do not modify the kit. just fit it on. The kit was made to fit the Freelander 1.8. I have fitted it to my Freelander, it works OK. Quote Link to comment Share on other sites More sharing options...
