TheHarv Posted May 4, 2009 Share Posted May 4, 2009 Been doing my H/G following the excellent write up in the tech archive except I had some work done on the head so I took the thermostat housing off The Payen head set has the 2 thermostat gaskets but I'm not sure which goes between head and (lower) t-stat housing and which is the (upper) thermostat gasket The papery one has a slightly larger hole and looks like it fits the bottom better The thicker fibre one looks like it would retain the lip of the t-stat Is this correct? Thanks! Quote Link to comment Share on other sites More sharing options...
western Posted May 4, 2009 Share Posted May 4, 2009 my 110 parts book shows these part numbers lower gasket to cylinder head 247874 http://www.lrseries.com/shop/product/listi...7874&page=1 upper between lower casting & upper casting ERR3682 http://www.lrseries.com/shop/product/listi...3682&page=1 parts book doesn't specify which material each is made from or internal hole diameter, But the 2 photo's in the links should show which gasket is which. Quote Link to comment Share on other sites More sharing options...
TheHarv Posted May 4, 2009 Author Share Posted May 4, 2009 Thanks Ralph appreciate the sleuthing - looks like the papery one goes one the bottom as suspected Quote Link to comment Share on other sites More sharing options...
western Posted May 4, 2009 Share Posted May 4, 2009 it's easy when the parts book is at hand & the LRSERIES website/online shop has loads of useful photo's of the subject parts. hth Quote Link to comment Share on other sites More sharing options...
