crazyfarmerboy Posted May 4, 2009 Share Posted May 4, 2009 hello, how do i get to the side indicators as they are inbetween the inner wing and the outer wing, do you have to access them via removing the from light pannel? thanks Quote Link to comment Share on other sites More sharing options...
pete3000 Posted May 4, 2009 Share Posted May 4, 2009 depending on the year they pull out, the later ones rounded slide back/forward a bit then pull out, the early longer ones pull out on a couple of pegs from memory. if you manage to break them they are a couple of quid. Pete Quote Link to comment Share on other sites More sharing options...
crazyfarmerboy Posted May 4, 2009 Author Share Posted May 4, 2009 on a 1985 110, the structure has rusted away and one is sagging off, i just had a quick look and could not work out how to get behind them, thanks Quote Link to comment Share on other sites More sharing options...
western Posted May 4, 2009 Share Posted May 4, 2009 plonk a picture up, as I'm not sure which type of side repeater you have. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted May 5, 2009 Share Posted May 5, 2009 A 1985 model I think will have a 'torpedo' type lamp unit with 2 screws holding it in. Remove floppy wheel arch to gain access to the nuts. Prepare for them to be rusted together, mine were . Had to drill the studs out of the lamp assembly to remove the whole thing from the wing [Requires care]. You'll still need the wheel arch off to fit the new lamp and get to the wiring. Part number 589143 shown below Hope this helps, Quote Link to comment Share on other sites More sharing options...
western Posted May 5, 2009 Share Posted May 5, 2009 as above ^^^^ Quote Link to comment Share on other sites More sharing options...
