Idris Posted May 10, 2009 Share Posted May 10, 2009 Installing electric fans from a Mondeo v6 as suggested elsewhere on this forum, to a 110 V8. Should the fan thermostatic switch go in the top hose or the bottom hose? Gerald Quote Link to comment Share on other sites More sharing options...
Aragorn Posted May 10, 2009 Share Posted May 10, 2009 The usual position would be half way up the radiator itself. if thats not possible, then i would suggest the bottom hose is the better option, as this gives you the temperature of the water leaving the rad. Quote Link to comment Share on other sites More sharing options...
Idris Posted May 10, 2009 Author Share Posted May 10, 2009 Thanks have installed an in line one in the bottom hose and adjusted it to come on at an appropriate temperature. However when it comes on is not consistent, that is it does not come on at the same temperature shown on the gauge each time. The gauge is of course measuring the temp at the top of the engine and it is at the bottom. Not sure if that is the issue or if the thermostatic switch is duff. Gerald Quote Link to comment Share on other sites More sharing options...
