Monster Posted May 15, 2009 Share Posted May 15, 2009 Hi Guys, I thought a timing belt change would be relatively simple affair!! I changed my timing belt on my 200tdi Discovery engine but now seems to run hot and vibrates more. I followed the land rover manual as follows; Put crank to TDC. Lock injection pump with drill bit. Remove belt, fit new one. I replaced tensioner, idler and belt. When i fitted new belt the injection pump gear was slightly out. So as suggested by the manual to move the three bolts and line all up again. I thought it best to get everything timed up so released bolts and inserted drill bit and locked it up. Now isnt a happy engine! Most people i speak to say they would just fit a new belt and go. I did try retard the timing of the pump and engine seemed to run smoother and cooler but how do i know if it is the correct timing? I then timed up as land rover suggested and now back to square one. I thought I saw a thread on here about something similar but cant seem to find it. The thing is if i had broken the belt i would have timed it up using LRs method. Any ideas guys. This is just another problem that i have encountered whilst trying to change the belt. Maybe should have just driven it til it broke. I am at wits end. Cheers. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 15, 2009 Share Posted May 15, 2009 Have a look through this thread - is that how you did it? http://forums.lr4x4.com/index.php?showtopic=14285 Les. Quote Link to comment Share on other sites More sharing options...
Monster Posted May 15, 2009 Author Share Posted May 15, 2009 Have a look through this thread - is that how you did it?http://forums.lr4x4.com/index.php?showtopic=14285 Les. Hi Les, I had a look through your thread before carrying out the change. This is pretty much how i did it, just that i had a disco 200tdi. I definitely remember fitting lining up the crank and injection pump but dont remember if there was an arrow on the backplate to line up the camshaft. I have attatched a pic prior to belt change. (white dots were already there). Not as good a photo as i hoped. Any thoughts? Thanks. Quote Link to comment Share on other sites More sharing options...
Mike Posted May 15, 2009 Share Posted May 15, 2009 Isn't there a pin that locks the flywheel through the flywheel drain hole as well? Not that I've ever used it when I've done the job. Quote Link to comment Share on other sites More sharing options...
