suggs Posted May 19, 2009 Share Posted May 19, 2009 looking at my 92 200 tdi 90 there seems to be only a lower pin bearing and the upper is just a thicker pin. is this correct? Quote Link to comment Share on other sites More sharing options...
ChrisM_110 Posted May 19, 2009 Share Posted May 19, 2009 Early top pin assembly is a pin, bush and thrust washer, lower is a pin and bearing. Later assembly, bearings top and bottom. You should be single bearing from your model year. Like this piccy. Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 19, 2009 Share Posted May 19, 2009 Will be what is known as a 'Railko bush' in the top, not a bearing. Taper bearing in the bottom, adjusted through shims under the top pin. Quote Link to comment Share on other sites More sharing options...
suggs Posted May 19, 2009 Author Share Posted May 19, 2009 yeah thats what i have same as the left hand diagram. other thing i need to ask is, ive got my hub and swivel assembly striped down to replace all bearings and gaskets etc after i had a bearing collapse and take out the stub axle, when i drift in the new bearing races do i lube them first or drift them in dry? cheers Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted May 19, 2009 Share Posted May 19, 2009 I did them dry, which is correct as far as I know. They rotate with the hub assembly, so there's no need for it to be lubed. Quote Link to comment Share on other sites More sharing options...
suggs Posted May 19, 2009 Author Share Posted May 19, 2009 yeah though that would be the case. Quote Link to comment Share on other sites More sharing options...
