Anderzander Posted May 19, 2009 Share Posted May 19, 2009 Is the adjuster for the cable accessed through the centre access panel? I thought it would be under the gaitor - but having looking there seems to be no adjustment there... Quote Link to comment Share on other sites More sharing options...
western Posted May 19, 2009 Share Posted May 19, 2009 lift the centre panel as you thought, 2 nuts IIRC 19MM each side of the bracket & adjust the shoes first then do the cable. Quote Link to comment Share on other sites More sharing options...
jacks906 Posted May 20, 2009 Share Posted May 20, 2009 is there shoe adjustmet on the 90's as mine dont have an adjuster on the drum like 110 have (mines a 300 90) dave Quote Link to comment Share on other sites More sharing options...
Anderzander Posted May 20, 2009 Author Share Posted May 20, 2009 Mine has shoe adjustment - its a 17mm hex head on the front facing side of the drum. The adjuster on the cable are a 21mm and 16mm nut ? wierd sizes. I've done mine but the adjustment feels like it should go further to make it impossible to get a 4th click - but the adjustment nuts are taking some turning. I've also developed a handbrake light fault after my last off road trip - possibly a break in the wire as the switch on the lever works - but the light flashes on and off on bumps - regardless of the position of the lever. Anyone know if the circuit breaks or is made to light up the dash? Quote Link to comment Share on other sites More sharing options...
western Posted May 20, 2009 Share Posted May 20, 2009 handbrake off the switch is extended so light is out & handbrake on means light is on. Quote Link to comment Share on other sites More sharing options...
