love2learn Posted May 19, 2009 Share Posted May 19, 2009 ticking noise wont get lost so im gonna change the outlet manifold under the advice of a friend. but cant see it anywhere tried paddocks and a couple of others anyone? 2.5 turbo diesel 1990 csw Quote Link to comment Share on other sites More sharing options...
western Posted May 19, 2009 Share Posted May 19, 2009 have you replaced the gasket that sits between the exhaust [outlet] maniflod & cylinder head ? if yes, try replacing the gasket under the turbo base to the manifold. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 20, 2009 Share Posted May 20, 2009 If you have an exhaust leak at a gasket joint - there'll be a sooty deposit where it's leaking. The TD engine is well known for the gasket leaking or the bolts working loose. Les. Quote Link to comment Share on other sites More sharing options...
love2learn Posted May 20, 2009 Author Share Posted May 20, 2009 thanx ill get under there and look at it like i say im going on the advice of a good friend who knows a good bit. better check it out though and thanx. Quote Link to comment Share on other sites More sharing options...
poohbear Posted May 20, 2009 Share Posted May 20, 2009 I have an exhaust manifold, turbo and down-pipe sat on a shelf if it is of any use to you Also have a complete 'head off' gasket kit which I never used if you get totally involved - this should have the exhaust manifold gasket in it. Dave. Quote Link to comment Share on other sites More sharing options...
