Strega Posted May 20, 2009 Share Posted May 20, 2009 Hi Guys, have bought a new head for a 300tdi and am unsure which thickness gasket to go for, any thoughts? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 20, 2009 Share Posted May 20, 2009 Same as the old gasket if you still have it or know how many notches it had in it. Some people just put the thickest gasket available on there (0-notches). You should measure piston protrusion to determine which is the correct gasket to use, which only requires a set of feeler guages and a straight edge. How to measure piston protrusion - http://forums.lr4x4.com/index.php?showtopic=24508 Les. Quote Link to comment Share on other sites More sharing options...
