ob1 Posted May 22, 2009 Share Posted May 22, 2009 Dumb question. Can, or can you not change between high and low range while in Diff Lock? Thanks Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 22, 2009 Share Posted May 22, 2009 Low to high, but you'd have to be careful going the opposite way. Les. Quote Link to comment Share on other sites More sharing options...
JST Posted May 22, 2009 Share Posted May 22, 2009 yes you can as Les says, either moving or stationary with difflock in or out. High to Low - recommendation is to come to a standstill to change - can be done if in diff lock or not. you can also engage and disengage diff lock on the move as long as all 4 wheels are traveling at approx same speed. ie straight ahead and not spinning. Quote Link to comment Share on other sites More sharing options...
Gromit Posted May 22, 2009 Share Posted May 22, 2009 As others have said, hi-low and diff lock are independant of each other. You can switch difflock in and out on the move providing no wheels are spinning. Changing from low to high on the move is: starting in low 3rd clutch down transfer box to neutral clutch up clutch down transfer to high main box to 2nd clutch up High to low can also be done on the move with care. I usually just stop to change. Quote Link to comment Share on other sites More sharing options...
JST Posted May 22, 2009 Share Posted May 22, 2009 i have found low 4th works better in the vehicles i have had to start the change from approx 15mph or so and at a constant unloaded speed if possible. The key to good change is move the transfer lever from Neutral to High as soon as the clutch goes in on the double declutch Quote Link to comment Share on other sites More sharing options...
Gromit Posted May 22, 2009 Share Posted May 22, 2009 i have found low 4th works better Thinking about it now, me too (it's been a while since I did it) Quote Link to comment Share on other sites More sharing options...
