BigMac1 Posted May 31, 2009 Share Posted May 31, 2009 Er honest answer is I don't know. Are there any serial numbers/markings etc on the unit or pump that would identify it? If so I'll have a look and let you know. Joining things with an 8mm compression joint sounds a tad technical, does it require special tools? Or is it a part bought from those nice people at Land Rover? Not sure about serial numbers. Western is the guru for that. The 8mm compression joint can be bought from a local hydraulics place. Think mine was about £2.50. All you need to fit is a hacksaw to cut the pipes, think its a 17mm spanner fitting and some emory tape to clean the edges of the pipe up. Mick. Quote Link to comment Share on other sites More sharing options...
