wiring on fuel tank
black on the stud cos it's the earth wire.
green should be green with black trace on front terminal & white should be white with slate trace on rear terminal
if you get these wrong, no panic just swap them over.
From my experience....clean the terminals on the fuel tank with a spray of wd40...and then scratch the the terminals a bit and then connect the wires.Helped me solve my fuel guage back to normal.
Cheers
Adi :)
 Share
