bmwmotogreg Posted May 23, 2009 Share Posted May 23, 2009 I am getting interested in a 96 Range Rover. Was told by the present owner that the only thing wrong w/ the the vehicle is that once every other day he gets a "P1715" message. Did a bit of research and found a reference to a "SSB inductive signature malfunction". Could someone kindly tell me what this means and what the potential solution is? (And what the parts cost to solve this issue?) Quote Link to comment Share on other sites More sharing options...
andyb Posted May 26, 2009 Share Posted May 26, 2009 It's full title is "Shift Solenoid B Inductive Signature Malfunction". The autobox has two solenoids for gear shift selection. First I'd check that you don't have a dirty connector and this is giving a high resistance and causing the fault. A good LR garage should be able to change a shift solenoid if that proves to be the problem. Quote Link to comment Share on other sites More sharing options...
