mike4444244 Posted May 23, 2009 Share Posted May 23, 2009 Hi Thinking of changing the shocks and springs on my 110, It has a +2" lift at the mo and I want to go back to standard height ish, (want to get 285 BFGs on) apart from anything else its use has changed and the insurance company always assume I'm a chav when I tell them about modified suspension Its a 110 van, galv chassis, 'HFH style' 'substantial' winch bumper and husky, big heavy brownchurch rack + tent, extra batteries, etc etc, basically its a bit lardy... I used to use it for my mobile workshop and P&P etc whereas now its more 'overlandy' and will be doing longish camping trips here and abroad etc as well as the odd P&P and laning... My choices at the mo are... HD LR genuine springs front and back, or HD 90 rear springs F and 130 Springs rear with or without the helper spring? I'll be keeping my Ironman shocks for now but when pennies allow I'd like to change them for correct length ones, I was thinking of OEM ones or decent aftermarket like deCarbon? Ta Mike Quote Link to comment Share on other sites More sharing options...
western Posted May 23, 2009 Share Posted May 23, 2009 probably be better off with 130 springs all round, taking into consideration the additional kit on board. Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted May 23, 2009 Author Share Posted May 23, 2009 Hi Ralph the 130 and 110 springs are the same on the front nrc9448/9449, interestingly this is the same number as the HD 90 rears, so it looks like the HD 110 fronts are the same spring as the 90 rears. The rear 110HD and 130 are the same spring too! Thats the first part of my question answered then Is it worthwhile fitting the 130 innner helper springs, the nrc6904, nrc6389 are 330lb in, the 130 inners are 140 lb in or will it make the ride too hard? Mike Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted June 3, 2009 Share Posted June 3, 2009 Mike, Only just seen this. I have a pair of genuine NRC9448's on the back of the Discovery, which I need to change for some slightly stiffer springs, probably going for HD90 rears (NRC9462). So you can have the NRC9448's for a suitable donation. Pete. Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted June 3, 2009 Author Share Posted June 3, 2009 Cool thanks Will hopefully be able to get back to the unit at beginning of July, am stuck in hospital or the library at the mo! No news from Richards yet... Mike Quote Link to comment Share on other sites More sharing options...
Pete Attryde Posted June 3, 2009 Share Posted June 3, 2009 Suits me, haven't been to unit much myself, although the Megajolt loom is now a proper one rather the lash up it used to be. Oh and you have a Robin nesting in your Nuts. Pete. Quote Link to comment Share on other sites More sharing options...
western Posted June 3, 2009 Share Posted June 3, 2009 with the extra kit on board, the 130 helper springs should be OK for the use you intend. Quote Link to comment Share on other sites More sharing options...
