smokinv8 Posted May 23, 2009 Share Posted May 23, 2009 Hi all, Stupid question time.....Should there be a rubber seal between the windscreen and roof on my 90 just the same as in a series vehicle or is it just plain siliconed in? Mines leaking if you hadnt already guessed! Neil Quote Link to comment Share on other sites More sharing options...
western Posted May 23, 2009 Share Posted May 23, 2009 Yes, but you can't see it from outside, there should be a seal fitted to the front underside of the roof & a foam type seal to the top of the screen frame & then the outside is sealed with a flexible sealant. Quote Link to comment Share on other sites More sharing options...
smokinv8 Posted May 24, 2009 Author Share Posted May 24, 2009 Yes, but you can't see it from outside, there should be a seal fitted to the front underside of the roof & a foam type seal to the top of the screen frame & then the outside is sealed with a flexible sealant. Ok cheers mate, best i get out the sealant gun 1st then. Quote Link to comment Share on other sites More sharing options...
