BOTH REAR ELECTRIC WINDOWS STOPPED WORKING
peter deer
Hi
always on the subject of electric windows :my REAR electric windows have stopped working (BOTH)
they do not work either from the central console switch or from the door switch
neither up or down
the front ones are OK
I thought :simple and easy ,it is the fuse
But the fuse is ok! Could it be a relay?
where would such a relay be ?
Please help
Peter
it is usually a bad joint in the window ECU. mine had the same problem, after spending 20 mins stripping the ECU out, re soldering, re fitting it - everything worked fine - for about the time it takes to fix them, next day they had stopped again - so it's going to be back out with the ecu for another soldering session
curiously ,the battery has now gone !!
i do not know if it is because of that electrical window problem ,or because I washed the wheel underach with a high pressure washer
Going to test now
Incidentally ,different layoput on mine :no ECU i can see behind the glove box see attachment:quite different from what was shown in the previous posts
Going to test now
haha ,there it was ,hiding !!!
just back !I have now tested the battery and ,would you believe ,everything is working fine !!
I suppose ,it will do it again ,sooner or later
but now ,i' know what to do !
many thanks for the expert advice
Peter
