Davecrx Posted May 24, 2009 Share Posted May 24, 2009 Hi Just would like a few ideas on how to stop the light from my spot lights on my light bar coming into the car and lighting up the dash as all i can see is the dash in the windscreen. If it helps i've got round lights that are about 5". I'll put a pic up as well. Thanks Dave Quote Link to comment Share on other sites More sharing options...
streaky Posted May 24, 2009 Share Posted May 24, 2009 You can make some upside down peaks which help eliminate alot of the light coming in. I made these for my rectangular lights and have since done the same for the round HIDs that I now have on the disco. It's only thin aluminium sheet. Make templates from cardboard first then screw them on with self tappers. Quote Link to comment Share on other sites More sharing options...
doda456 Posted May 24, 2009 Share Posted May 24, 2009 I agree with streakys method, ive done similar to mine and it works a treat. Just modify streakys design to fit your round lights, or try making a hood out a a bit of tube if you happen to have any Dan Quote Link to comment Share on other sites More sharing options...
andy2986 Posted May 24, 2009 Share Posted May 24, 2009 I put a small piece of tape on the bottom of the lens, stops allot of the spill into the cab. Andy Quote Link to comment Share on other sites More sharing options...
streaky Posted May 25, 2009 Share Posted May 25, 2009 I put a small piece of tape on the bottom of the lens, stops allot of the spill into the cab.Andy I also tried the same method Andy and although it does help a little bit...it also reduces the ammount of light coming from the reflector. This is the only pic I can find with my round light peaks. I hope it shows up clearly on this rather small photo? Quote Link to comment Share on other sites More sharing options...
