draper40 Posted May 24, 2009 Share Posted May 24, 2009 Hey, I have a warn XD9000i and find the rope really hard to pull out when the winch is in freespool. I thought it may just be me but I tried and new champion winch and you have to put no effort in whatsoever. What could be causing the freespool to be so tough and how can I make it really easy? Thanks Pete Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 24, 2009 Share Posted May 24, 2009 Has the winch been serviced lately? if it has been dunked it could be corroded, and full-o-crud. Quote Link to comment Share on other sites More sharing options...
bishbosh Posted May 24, 2009 Share Posted May 24, 2009 My money is on the internal brake. Either that or your winch tray is not flat and the winch end casings are being twisted out of plane when you tighten the bolts. Try loosening the holding down bolts. If the free spool frees up then you have found your problem. If not, it is time for a rebuild and brake service. Quote Link to comment Share on other sites More sharing options...
draper40 Posted May 24, 2009 Author Share Posted May 24, 2009 It was rebuilt with a new brake from warn about 3 months ago. Bish- I'll try loosening the bolts tomorrow. Thanks Pete Quote Link to comment Share on other sites More sharing options...
western Posted May 24, 2009 Share Posted May 24, 2009 Reckon you should send it back as not usable. Quote Link to comment Share on other sites More sharing options...
draper40 Posted May 25, 2009 Author Share Posted May 25, 2009 Send what back- the brake? Pete P.s. It was me that rebuilt it. Quote Link to comment Share on other sites More sharing options...
western Posted May 25, 2009 Share Posted May 25, 2009 Send what back- the brake?Pete P.s. It was me that rebuilt it. in that case give yourself a slap or fit a Husky which doesn't have a in drum brake. Quote Link to comment Share on other sites More sharing options...
draper40 Posted May 26, 2009 Author Share Posted May 26, 2009 I undid the bolts partialy today and it did not help and so it sounds like a brake problem. Assuming the new brake mechanism is not faulty what is the problem and how do I fix it? Thanks Pete Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted May 26, 2009 Share Posted May 26, 2009 Dont forget the champion winches have a good freespool. the first time I tried mine I nearly fell over, I was expecting the same resistance as my old Ramsey. Quote Link to comment Share on other sites More sharing options...
gwyn lewis Posted May 27, 2009 Share Posted May 27, 2009 It Sound like you have to much grease on the outside of the Ring Gear, and in the end housing no 18 and no 1 on a parts diagram if you can see one , this causes to much resistance and makes it hard to pull out, as this must spin frely when in free spool , this is comon on a lot of lowline winches after they have been serviced, as to much grease is put on the outside of the Ring Gear , use a light oil on the outside of the Ring Gear it should help Gwyn Lewis Quote Link to comment Share on other sites More sharing options...
landy andy. Posted May 28, 2009 Share Posted May 28, 2009 Where do you get the rebuild kits from for Warn winches/ Andy Quote Link to comment Share on other sites More sharing options...
draper40 Posted May 29, 2009 Author Share Posted May 29, 2009 I got them from here . Unfortunately they only deliver to US, but I could bring any bits back and post them if you wanted. Quote Link to comment Share on other sites More sharing options...
western Posted May 29, 2009 Share Posted May 29, 2009 Try Arbil4x4 as they are the current Warn importer. http://www.arbil4x4.co.uk/category.php?category=2 Quote Link to comment Share on other sites More sharing options...
landy andy. Posted May 29, 2009 Share Posted May 29, 2009 Thanks for that, will give them a ring. Andy Quote Link to comment Share on other sites More sharing options...
