Mack Posted May 24, 2009 Share Posted May 24, 2009 Anybody can share a picture showing the drain plug on the swivel ball? I`m thinking on fitting them on the sealed ones. cheers M Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 25, 2009 Share Posted May 25, 2009 Les. Quote Link to comment Share on other sites More sharing options...
western Posted May 25, 2009 Share Posted May 25, 2009 Anybody can share a picture showing the drain plug on the swivel ball? I`m thinking on fitting them on the sealed ones.cheers M it's on the outer swivel not the ball part as in the photo above ^^^^ Quote Link to comment Share on other sites More sharing options...
Mack Posted May 26, 2009 Author Share Posted May 26, 2009 Thank you guys. I assume all SB´s are made of the same spec in terms of wall thickness, strength, etc Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted May 26, 2009 Share Posted May 26, 2009 I don't know if I would bother - when I took the bolt out of mine yesterday it dripped so slowly that I ended up taking out the bolts that hold the bottom swivel pin and draining it through them.. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 26, 2009 Share Posted May 26, 2009 Top the ball up with engine oil, then go for a drive. The two will mix and then drain out quicker. Les. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted May 26, 2009 Share Posted May 26, 2009 Top the ball up with engine oil, then go for a drive. The two will mix and then drain out quicker. Nice idea - if you can go for drive Quote Link to comment Share on other sites More sharing options...
dantd5 Posted May 26, 2009 Share Posted May 26, 2009 Top the ball up with engine oil, then go for a drive. The two will mix and then drain out quicker.Les. Remember to put back the drain plug when the mixture of engine oil and one-shot are in place bofre going for the drive. Neighbors, in-laws and wifey simply hate to see driveway or tarmac marked Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2009 Share Posted May 26, 2009 Thank you guys. I assume all SB´s are made of the same spec in terms of wall thickness, strength, etc Would reckon so, altough the later/current ones are Teflon covered instead of chrome plated/ Quote Link to comment Share on other sites More sharing options...
