sheltie50 Posted May 24, 2009 Share Posted May 24, 2009 Can the Crank sensor air gap be set up without the tool required.anyone know the air gap required? P38 which is a poor starter. Quote Link to comment Share on other sites More sharing options...
western Posted May 26, 2009 Share Posted May 26, 2009 RAVE workshop manual only says fit & set the gap using the special tool. can't find any measurement info in RAVE manual. Quote Link to comment Share on other sites More sharing options...
sheltie50 Posted May 27, 2009 Author Share Posted May 27, 2009 Thank you , I came to the same conclusion but was hoping someone might have seen the setting, as it happens, advise is that this is not the answer to my poor starting problem, P38 should read 38p, it's all these will leave you with ;-) Quote Link to comment Share on other sites More sharing options...
steve_d Posted May 28, 2009 Share Posted May 28, 2009 If it's any help I have sensors on two different cars which are both set to 1mm gap. VR sensor for Megasquirt and a speedo sensor on my sports car. Steve Quote Link to comment Share on other sites More sharing options...
