Olsin PETRO Posted May 25, 2009 Share Posted May 25, 2009 I was testing my fathers disco in the t4 yesterday as i don't like the starting of that car. It starts each time but not as it should. I managed to get this fault code. Fuel temperature sensor, it shows -112 degrees. it says take out fuel pump and change it. I checked in the workshop manual but i can't find it how. Is the first time for me to get this error. anyone knows this??? Help please!! Quote Link to comment Share on other sites More sharing options...
Ally V8 Posted May 25, 2009 Share Posted May 25, 2009 The fuel temp sensor is inside the top of the injector pump,so not easy to get at.Much more likely a connector fault or broken wire,so some checking with a multimeter would be a good start.They often show very low sensor temps when open circuit,rather than a grey out of range reading or the normal )))) sign in grey on the T4 screen. Quote Link to comment Share on other sites More sharing options...
Guest DiscoTD4 Posted May 26, 2009 Share Posted May 26, 2009 I was testing my fathers disco in the t4 yesterday as i don't like the starting of that car.It starts each time but not as it should. I managed to get this fault code. Fuel temperature sensor, it shows -112 degrees. it says take out fuel pump and change it. I checked in the workshop manual but i can't find it how. Is the first time for me to get this error. anyone knows this??? Help please!! Hi - out of interest what are the symptoms of the starting issue ? My Tdi300 auto EDC fuel temp senor measures around 2.6k ohm at approx 15 deg C (from memory), but I've no idea if this is per spec and mines never a good starter although runs fine. I've eliminated everything to date apart from a worn start of injection timing solenoid and this temp sensor so am interested in any info you could provide. Cheers Quote Link to comment Share on other sites More sharing options...
